Program Compustar Remote, Unlock All Doors
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=146169
Printed Date: May 07, 2026 at 8:50 AM
Topic: Program Compustar Remote, Unlock All Doors
Posted By: cityslicker0123
Subject: Program Compustar Remote, Unlock All Doors
Date Posted: April 28, 2020 at 5:29 PM
I just purchased a new truck and it has a compustar remote start. I can’t get the remote to unlock all doors instead of driver door, what do I need to do? I added a dronemobile to it because the antenna was taken out. Is there something I change on module or in the programming of remote?
Posted By: kreg357
Date Posted: April 29, 2020 at 6:13 AM
We would need more info to assist you.
What Year, Make and Model of truck?
What Model Compustar system?
What bypass module ( if any )?
Depending on the vehicle and the bypass model used, it might be possible to set the Compustar or the bypass module to "double pulse Unlock output" and get all the doors to unlock but...
Changing the Compustar programming options requires either the remotes or an OP-500 programmer. It's not a simple switch setting. Don't think you can do it with DromeMobile, either.
That being said, you can get a 4 button Remote Kit that includes the antenna, antenna harness and two 4 Button remotes for $30 off eBay. Search on "RF-1WG15-AM"
