Shut Down Feature in Alarm System
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=146184
Printed Date: May 15, 2026 at 9:47 PM
Topic: Shut Down Feature in Alarm System
Posted By: securelabs
Subject: Shut Down Feature in Alarm System
Date Posted: May 04, 2020 at 9:57 PM
I once a an alarm system with an immbilizer thing I believe, when the car starts it will drive for 30 sec then shut down and alarm will go off and will not restart until I do a lock/unlock sequence with the power lock switch.
The feature had to be enabled a certain way too. Using the alarms remote would not disable this.
Anyone ever had this feature or know what is required
------------- Securelabs
Posted By: davep.
Date Posted: May 05, 2020 at 8:40 PM
I had a similar "anti-hijack" deal in my 93 s-blazer. Wasn't interfaced to the horn, however. It was defeated by a hidden toggle switch, you had to hit the toggle within about 30 seconds or the truck died and wouldn't re-start. It came from Jacobs Electronics. Jacobs had a big catalog of stuff and full of hype. The anti-hijack device lasted about 5 years and failed electronically. As I recall, the Jacobs stuff became known for not being very good.
