Door Trigger Location
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=146433
Printed Date: May 15, 2026 at 5:54 AM
Topic: Door Trigger Location
Posted By: bessflick
Subject: Door Trigger Location
Date Posted: September 09, 2020 at 5:58 AM
Blessed day I am requesting information on the most commonly used procedure for wiring door triggers to alarms. I mostly use the door triggers of each door and diode isolate. However can another method be used to safely trigger all doors and in some cases the trunk? Some vehicle dosen't have door triggers and to trace all the wires are just cumbersome. Any assistance would be appreciated. Thanks
Bessflick
Posted By: silvercivicsir
Date Posted: September 09, 2020 at 9:35 AM
best bet would be to look and see if the trunk has a trunk light.. If it does, pull the bulb and look at the colors.. if there is no trunk light, zero chance it will have a trunk pin.
