Diodes, 1A4 vs IN4001
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=146521
Printed Date: May 14, 2026 at 6:22 AM
Topic: Diodes, 1A4 vs IN4001
Posted By: charger47
Subject: Diodes, 1A4 vs IN4001
Date Posted: October 27, 2020 at 11:23 AM
Hi need some help about diode specification unlock and lock door cause im installing ford edge 2011 need a diode require for ADS-ALCA bypass but i have only 1A4 diode that require on the drawing was IN4001 diode can i use 1A4 diode? Thanks your help i really appreciated.
Posted By: geepherder
Date Posted: October 27, 2020 at 5:27 PM
It doesn't need to carry much current, so as long as it's not a zener diode you should be fine.
------------- My ex once told me I have a perfect face for radio.
Posted By: kreg357
Date Posted: October 28, 2020 at 7:53 AM
Found this on the internet :
You can replace 1A4 with RL207, RL206, RL205, RL204, HER208, HER207, HER206, HER205, HER158, HER157, HER156, HER155, HER108, HER107, HER106, HER105, FR207, FR206, FR205, FR204, FR157, FR156, FR155, FR154, FR107, FR106, FR105, FR104, EM520, EM516, EM513, BY133, 1U8, 1U7, 1U6, 1U5, 1N5399, 1N5398, 1N5397, 1N5395, 1N4937, 1N4936, 1N4007, 1N4006, 1N4005, 1N4004, 1A7, 1A6, 1A5, SF16, SF18, SF26, SF28, UF4004, UF4005, UF4006, UF4007, 1N4004G, 1N4005G, 1N4006G, 1N4007G, 1N4936G, 1N4937G
I typically use 1N4004 and 1N4007 diodes in place of the 1N4001 diodes, so you should be fine.
------------- Soldering is fun!
Posted By: i am an idiot
Date Posted: October 28, 2020 at 9:02 AM
The only difference from a 4001 to a 4004 or 4007 is the voltage. A 4001 is rated at 50 volts, the others are rated at higher voltages. You will be fine with the 1A4
Date Posted: October 29, 2020 at 9:21 AM
Thanks! got it thanks for all reply very useful.
