2007 Nissan Sentra, Type B Door Locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=146578
Printed Date: May 14, 2026 at 10:49 AM
Topic: 2007 Nissan Sentra, Type B Door Locks
Posted By: charger47
Subject: 2007 Nissan Sentra, Type B Door Locks
Date Posted: November 26, 2020 at 5:48 PM
H! I want to install Remote Start Python 4106P with Evokey Bypass, but the door is Type B Lock/Unlock, need a relay to install this? This the Nissan Sentra wire on the door: POWER LOCK       RED (TYPE B)
      POWER UNLOCK PINK (TYPE B)
Then on R/S need to wire disarm/arm? or not needed? Your help much appreciated. Thanks
Posted By: geepherder
Date Posted: November 27, 2020 at 1:29 AM
Type B is the most common type. Your door lock outputs should connect directly to the lock/unlock wires of the car to switch the factory relays. Just make sure to verify the wires with a meter before making your connections.
