2013 Chevrolet Equinox Doesn’t Start With Key
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=146657
Printed Date: May 15, 2026 at 4:01 PM
Topic: 2013 Chevrolet Equinox Doesn’t Start With Key
Posted By: veysma
Subject: 2013 Chevrolet Equinox Doesn’t Start With Key
Date Posted: January 06, 2021 at 1:32 PM
We installed a remote start (FLRSGM7) on a 2013 Chevy Equinox back in September. The customer drops the vehicle off yesterday before we open and calls to tell us that the vehicle hasn’t started with the key since about 2 weeks after the install but didn’t get a chance to get in touch with us. The only way to start the vehicle is with the remote starter we installed and oddly enough after you remote start the vehicle you can start it with the key but if the vehicle sits for 20 minutes or so it goes back to not working again. The key works fine in accessory but when you turn to start all lights and radio shut off. I’m thinking it might be an issue with either the ignition or the key (customer only has 1 key) but this one has me stumped.
Posted By: silvercivicsir
Date Posted: January 08, 2021 at 10:55 AM
is the pk3 fuse blown? the 2 amper?
Posted By: veysma
Date Posted: February 22, 2021 at 12:36 PM
Just wanted to give an update in case someone ever runs into this issue. It ended up being a bad key. After being accused of everything under the sun from the customer and being asked if we were going to pay for a replacement since obviously the remote starter broke his key :V:
