451M Door Lock Relay Issues 1994 Ford Econoline
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=146880
Printed Date: May 14, 2026 at 10:44 PM
Topic: 451M Door Lock Relay Issues 1994 Ford Econoline
Posted By: snowytires
Subject: 451M Door Lock Relay Issues 1994 Ford Econoline
Date Posted: June 11, 2021 at 1:33 AM
I’m installing an Avital 3100LX alarm and am trying to get the keyless entry working. My van has reverse polarity locks and I’m 80% sure I need a relay so I bought one and connected it to the passenger kick panel red and brown wires.
I currently have white and black wire connected to red lock wire leading to door.
Green wire connected to red lock wire leading to engine.
Brown wire connected to brown unlock wire leading to door.
Blue wire connected to brown unlock wire leading to engine.
I’ve tried purple wire grounded and to constant 12v and still doesn’t work. The lock and unlock buttons on the door work, but the key fob does not. I hear the relay clicking but it doesn’t affect the locks. I’m at such a loss. I tried even reversing the wires, white and brown leading to the engine and nothing.
What am I doing wrong?
Date Posted: June 11, 2021 at 9:21 AM
1994*** Econoline sorry!
Posted By: mgoetz74
Date Posted: June 11, 2021 at 1:05 PM
the 451m for five wire would be
white/black   brown lock wire going toward the switch
green/black   brown lock wire going away from the switch
brown/black red wire going towards the switch
blue/black   red wire going away from the switch
purple and the purple/black wire to a +12 constant
If it came with a factory key fob for keyless entry
purple and purple/black to +12 constant
white/black and brown/black not used
green/black - should be a pink/yellow and a pinky/green @ passenger switch, need to test but should show + when you hit lock or unlock, does not says which is which
blue/black - should be a pink/yellow and a pinky/green @ passenger switch, need to test but should show + when you hit lock or unlock, does not says which is which
