Viper 160XVL Upgrade To Viper 4806V, 2009 Pontiac G6
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=146973
Printed Date: May 15, 2026 at 3:43 AM
Topic: Viper 160XVL Upgrade To Viper 4806V, 2009 Pontiac G6
Posted By: stittville ed
Subject: Viper 160XVL Upgrade To Viper 4806V, 2009 Pontiac G6
Date Posted: August 12, 2021 at 11:20 AM
My Daughters car is a 2009 Pontiac G6. I installed the Viper 160XVL a number of years ago and it works fine but the Remote plastic case will not stay together even when I used Helicopter Tape on them. No new remotes seem to be available or a replacement remote. I have a Viper 4806V as a replacement/upgrade. The 160XVL has a separate Relay box but the Viper 4086V does not.
So my first question is do I need a relay for the 4806V Starter circuit or any of the other items that need to be connected ???
I do have a Fortin CAN SL-2 installed now that I would like to reuse.
Thank You for any help with this install.
------------- Stittville Ed
Posted By: silvercivicsir
Date Posted: August 12, 2021 at 2:07 PM
you could use all the neg triggers from the 4806, and connect those to the relay box. But you are only saving yourself like 5 wires... I would just start from scratch and install the 4806, but leave the wires long on 160xvl. should be just a game of matching the colors.
Posted By: geepherder
Date Posted: August 12, 2021 at 8:31 PM
Something else to consider is a cover for the remote. There are kinds with a snap closure, and I think you can also get silicone stretch-on type.
I use something like this (not my affiliate link, just came up in a search): https://www.amazon.com/Black-Leather-7856V-7656V-Remote/dp/B00J843WMW/ref=sr_1_7?dchild=1&keywords=viper+remote+case&qid=1628818085&sr=8-7------------- My ex once told me I have a perfect face for radio.
Date Posted: August 13, 2021 at 7:05 AM
That was kind of mmy plan
Thanks Ed ------------- Stittville Ed
Date Posted: August 13, 2021 at 7:08 AM
The 160xvl is a funny remote, it has a Antenna on ot and a weird shape. They also seem to have some resistance when you try to squeeze them together.
Thanks,
Ed
Date Posted: August 16, 2021 at 1:33 PM
I have installed the new 4806V to replace the 160XVL. The door lock, unlock and trunk unlock work fine. The Remote Start will not work. I have not found the correct connection to connect the Neutral Safety Switch wires to and do not have the Neutral Safety Switch connected which I assume is the problem. The 160VXL connection for the Neutral Safety switch is a Negative Input. So my question is which wire on the 4806V should I use to complete the Neutral Safety switch connection ?????
Date Posted: August 16, 2021 at 3:21 PM
I think I may have to get it out of the MTS mode........... Any simple way to make the change or is this some thing a Bit Writer is needed ????????
Date Posted: August 16, 2021 at 4:45 PM
I did get the car to Remote Start. I connected the Black/White Strip wire to the Neutral Safety Switch which I had done before but the problem is that DEI ships the unit in the Manual Transmission Mode. Then I had to remember how to read and used the directions on how to program the system to the Automatic Transmission option mode.
