Compustar CS4900-S, Run Time Program Issue
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=146986
Printed Date: May 15, 2026 at 9:05 AM
Topic: Compustar CS4900-S, Run Time Program Issue
Posted By: stslimited84
Subject: Compustar CS4900-S, Run Time Program Issue
Date Posted: August 17, 2021 at 11:58 AM
I've followed the instructions from this post: https://www.the12volt.com/installbay/forum_posts.asp?tid=144847&tpn=2#reply as well as from the manual itself which closely mirrors the instructions from that post obviously. The issue I'm having is the system doesnt respond to the button presses on either the 2 way or 1 way remote so I'm unable to make any changes.
Any help is appreciated! Thank you
The vehicle is a 2013 Ford Escape. The remote start functions normally otherwise. I'm trying to change the run time from 15 mins to 45 mins.
Posted By: audiokid1
Date Posted: August 17, 2021 at 7:42 PM
Make sure the transmitters are programmed to the module first, before you start feature programming. I believe they cover it in page 5-6 of the installation manual.
Date Posted: August 18, 2021 at 6:55 AM
I didn't do the install but according to the manual, the two remotes are preprogrammed to the control module already. They function fine - lock, unlock and remote start the car as expected. You're saying I should reprogram them to the module anyway?
Date Posted: August 18, 2021 at 7:21 AM
If that is the case then the transmitters are fine. Transmitters don't always come pre-programmed. You may just be missing a simple step in the programming process. Note: When programming with the transmitters you only have x-amount of time for each step before the module automatically exists programming. So be prepared to press buttons without hesitation.
Date Posted: August 18, 2021 at 7:24 AM
Thanks for replying. When pressing the button combos as described, I get no reaction from the vehicle whatsoever - no chirp or light flash. I've tried with both the 1 way and 2 way remotes - same result of nothing happening. Is it possible its a different module than the cm900 as listed in the forum? or am I missing something?
Date Posted: August 18, 2021 at 9:24 AM
The module part number should be on the backside of the module. Confirm it is a CM-900.
Date Posted: August 18, 2021 at 9:31 AM
Will do. Where would the module be located typically?
Date Posted: August 18, 2021 at 10:23 AM
The BCM on a 2013 Ford Escape is behind the glovebox, so I am betting that is where you will find the module.
