2006 Ford F-150, Heated Mirrors to be Triggered by Avital 4105
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=147100
Printed Date: May 14, 2026 at 12:12 PM
Topic: 2006 Ford F-150, Heated Mirrors to be Triggered by Avital 4105
Posted By: heezy101
Subject: 2006 Ford F-150, Heated Mirrors to be Triggered by Avital 4105
Date Posted: October 26, 2021 at 9:06 PM
Hello!
I'm trying to have my Avital 4105L trigger the heated mirrors on my truck. In this truck the heated mirror switch is part of the climate control module and I can't seem to locate a diagram of the two connectors on that module. I was hoping someone would have that diagram, or that someone else has done this using a different solution I'm not thinking of.
Thanks in advance for any help!
2006 F150 Supercrew V8 6.5' Bed
Posted By: kreg357
Date Posted: October 26, 2021 at 9:32 PM
Greetings
The info I have is that the Mirror Defrosters are tied in with the Rear Defroster, so using the wire listed below would turn on both. It's possible with the full vehicle wiring diagram you might be able to turn on just the side view mirror(s) defroster with a 5-Wire relay setup to the correct wire.   Here is the basic Rear Defroster / side view mirror defroster turn on.
Rear Defroster......Dark Blue/Orange (-).......@ HVAC Control Module in dash, 26 pin plug, pin 10
Mirror Defroster...............................(same as rear defroster)
You could use the 4105 Pin 5 BLUE/WHITE (-) 200 mA 2ND STATUS/REAR DEFOGGER wire with a programming change to Menu 2, Feature 8 to Option 2.
Posted By: heezy101
Date Posted: October 26, 2021 at 9:38 PM
Thank you so much! This is exactly what I was looking for. I appreciate your help!
