Starter Relay Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=147159
Printed Date: April 19, 2026 at 1:19 PM
Topic: Starter Relay Wiring
Posted By: martprez
Subject: Starter Relay Wiring
Date Posted: December 02, 2021 at 1:53 AM
Hi there, I bought an ebay car alarm/immobiliser kit to be installed for used to keyless entry for car. Everything is fine except for starter relay wiring. Im using a 5 pin relay and wired as pin 30 for starter(ignition side), 87a for starter (starter side), pin 86 for 12v supply and pin 85 for the alarm output, that supposed to be to a negative output when alarm is armed. The problem I’m having is not working the relay to charge. I have connected a ground wire to pin 85 and it works the relay. I have checked the negative wire output and only showing only few millivolts in multimeter.
------------- mart.prez
Posted By: i am an idiot
Date Posted: December 02, 2021 at 7:19 PM
The alarm brain is defective.
------------- Let's Go Brandon Brown. Congratulations on your first Xfinity Series Win. LGBFJB
Posted By: mgoetz74
Date Posted: December 03, 2021 at 12:10 PM
is there a diode between 86 and 85 with the stripe side (cathode) towards 86?
------------- 33 years as a installer now just a retired old guy. Favorite thing to install/topic are remote starts/car alarms. Stop using test lights!!!
