Viper 5701, Brake Shutdown Error, 2002 Pontiac Aztek
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=147519
Printed Date: May 15, 2026 at 6:39 AM
Topic: Viper 5701, Brake Shutdown Error, 2002 Pontiac Aztek
Posted By: fenderunbender
Subject: Viper 5701, Brake Shutdown Error, 2002 Pontiac Aztek
Date Posted: November 26, 2022 at 4:59 PM
I have a Viper 5701 that is installed in an '02 Pontiac Aztek. I did the installation myself 2 months ago and it has been working perfect until now. I accidentally triggered the alarm and after disarming it and driving home in the dark the flashing light was driving me crazy. I could not recall how to make it stop so I pressed the Valet/Program button a few random times and it stopped. The next day, the remote start and the door locks have stopped working. When I run the diagnostics on it, I get 5 flashes (brake shutdown).
I have pulled the module out and double checked all of the wiring connections and continuity checked the brake wire and it is good. Now I'm at a loss of what other wires I can check that might give me this error or by randomly pressing the Valet switch did I mess something up?
Date Posted: November 26, 2022 at 5:22 PM
There is zero voltage on the brown brake wire until I step on the brakes and then I get 12v so I know that part of the circuit is working correctly.
Date Posted: November 27, 2022 at 3:46 PM
Maybe someone else can learn from my simple mistake.
Just like I suspected, user error. I have a second module I installed and I got the same brake shutdown error. That is when I realized it wasn't an error at all, it was just telling me how it shut down last time. After I installed the second module, when I paired the remote it worked like it should have. So, whatever I did in a panic the first time to shut the alarm off and kill the valet light, I must have caused it to lose the pairing with the remote.
Plus as a sidenote, I did not misspell Aztek in the title. Someone edited the title and made the mistake of spelling it Aztec instead of Aztek. HA!
