How do I wire a switch?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=14773
Printed Date: March 13, 2026 at 5:25 AM
Topic: How do I wire a switch?
Posted By: gizmosrealm1
Subject: How do I wire a switch?
Date Posted: June 11, 2003 at 3:26 PM
Hey guys.  I'm trying to wire power door locks into my '92 civic.  I'm using 2 relays, 2 actuators, and a momentary switch.  I've checked out the diagrams here on this site, but all seem to use an alarm as part the circuit.  I would like to wire the door locks up without using an alarm since I don't have one right now.  So, how do I wire this together to run off just a switch?  Can I add an alarm w/ keyless entry in the future to this?  Thanks in advance for any help.
Date Posted: June 11, 2003 at 3:33 PM
to help clarify, the actuators I have have 2 wires.  They need negative on one and positive on the other to push.  The polarity needs to then be reversed (ie-negative to positive and positive to negative) to pull.  The actuators are made by IMPACT if that helps.
Posted By: xetmes
Date Posted: June 11, 2003 at 3:42 PM
just use the set-up from this site, but instead of the alarm input use the switch, i rocker switch is the easiest to hook up this way.
Posted By: xetmes
Date Posted: June 11, 2003 at 3:47 PM
ohh the reason i say to do that is so that if you want to add an alarm in the future, you can just hook it up to the already existing relays
Posted By: jrilla
Date Posted: June 11, 2003 at 3:57 PM
Just like xetmes said, use forth diagram down from the top of the page that this link takes you to:
Relay Page
You just need to connect the two outside pins from the switch to the either of the pins on the relay that are currently connected to the alarm output. Then the center pin on the switch should would go to chasis ground.
J Rilla
Owner/Installer
Date Posted: June 11, 2003 at 5:55 PM
Thanks for the info...one more question though, should I be using the 5-wire hookup or the reverse polarity hookup?  I was thinking reverse polarity.
Posted By: rudbwoy69camaro
Date Posted: June 11, 2003 at 6:28 PM
Reverse polarity, it worked for me...
My switch issue
I had to put one on my '91 Integra, but it wasn't like the wiring diagrams posted on here.  Lucky I have a car alarm and started probing around with a ground and hit the right pins for lock and unlock and tapped in.  I'll go check it out...
posted_image
Date Posted: June 11, 2003 at 6:34 PM
Thanks for all the help, I'll go try it out.  Ignore my earlier post, JRILLA already said use the 4th on down in the post prior to it.  My bad ;-)
Date Posted: June 12, 2003 at 3:49 PM
Thanks everybody for the help, I got it all wired up and it works great!!
Posted By: xetmes
Date Posted: June 12, 2003 at 4:40 PM
cool  posted_image
