2007 Acura MDX, Power Tail Gate Opener
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=148027
Printed Date: May 14, 2026 at 11:25 PM
Topic: 2007 Acura MDX, Power Tail Gate Opener
Posted By: hiltonle1975
Subject: 2007 Acura MDX, Power Tail Gate Opener
Date Posted: May 10, 2024 at 11:17 PM
I have 2007 acura mdx I install remote start now I have a problem with wiring relay for power tail gate opener
Please help !
Posted By: kreg357
Date Posted: May 11, 2024 at 9:49 AM
At the dash fuse box locate the Green 21 Pin connector (upper left).   There will be a White wire and a Brown wire directly across from each other at Pins 6 and 18.
Relay wiring :
Relay Pim 85 to R/S (-) Trunk Release output
Relay Pin 86 to +12V constant
Relay Pin 87 to White wire
Relay Pin 30 to Brown wire
Relay Pin 87A not used - insulate
Date Posted: May 11, 2024 at 10:07 PM
Thank you so much for the information
