Clifford 650 MK3, Intellistart And Blackjax, UK 2008 Ford Fusion
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=148035
Printed Date: April 17, 2026 at 9:17 AM
Topic: Clifford 650 MK3, Intellistart And Blackjax, UK 2008 Ford Fusion
Posted By: sparkmotorwurks
Subject: Clifford 650 MK3, Intellistart And Blackjax, UK 2008 Ford Fusion
Date Posted: May 16, 2024 at 4:11 PM
Hi guys, new to the forum here. Hope everyone's well.
I've got a clifford 650 Mk3 that I'm going to install to a UK 2008 ford fusion.
I've also ordered the intellistart 4 module and blackjax 5 module which I need help with
Looking at the diagrams it says to connect the intellistart / blackjax via the data port but there's only one port and my alarm hasn't come with the data port connector, only wire I have is the one from the self powered siren that plugs into the red port and has a shorter data port extension lead
Is there anywhere I could purchase the lead from in the UK? Or would I still be able to use the intellistart and wire The blackjax separately
Help would be appreciated
Thanks, Ketan
Date Posted: May 16, 2024 at 5:29 PM
UPDATE: I've just done some research and the intellistart module connects to the clifford 650 alarm brain via the data port.
The blackjax doesn't connect into the Clifford 650 brain from what diagrams I've seen so far.
