2024 Acura Integra Aspec, Manual Transmission, Remote Start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=148160
Printed Date: May 14, 2026 at 8:44 PM
Topic: 2024 Acura Integra Aspec, Manual Transmission, Remote Start
Posted By: bikejunkie81
Subject: 2024 Acura Integra Aspec, Manual Transmission, Remote Start
Date Posted: September 22, 2024 at 12:51 PM
{ Hopefully this is in the right place.}
Hi all! So I have a 2024 Integra Aspec with a 6 speed manual transmission that I'm trying to put a remote start in. The remote start is an Evo one and I do have the the fortin flashlink. I have the install sheet #102701 completed. So wiring is hooked up, unit is programmed and key is cryptored. I bought the unit off of Amazon and when I tried calling Fortin for help, I got all the way to telling I have a manual transmission and he sad he couldn't help me anymore. I have to call amazon and they are not very helpful either. So I cant get the key fob to start my car, I know that its programmed because the fortin tech had looked it up and said it was plus I verified it by putting it in valet mode. I did the whole idle mode and ready mode to prepare for the next time to remote start it but every time it shutdown. I hold the start/stop button for 3 seconds per the instructions and it just shuts off. So any help would be greatly appreciated. Thanks
Date Posted: September 22, 2024 at 12:52 PM
It is a push to start by the way, any other info just let me know!
Date Posted: September 25, 2024 at 1:19 PM
Did I word something wrong and that's why no one will respond to this or not enough info. Please just let me know because I would like to get this figured out.
Posted By: lee.lopez
Date Posted: September 26, 2024 at 3:41 AM
posted_image
Posted By: chev104275
Date Posted: September 26, 2024 at 11:19 AM
I've never done this car but in reading the install guide says you need the door closed to start the sequence for remote start. Are you trying this with any of the doors or hood open ?
Date Posted: September 27, 2024 at 7:26 PM
No everything is closed. It keeps telling me that I'm doing the start sequence wrong, so I'm not sure how to troubleshoot that
Date Posted: September 27, 2024 at 8:17 PM
If you can't get it to work you might try Idatalink. Idatalink has manual transmission listed as supported:
https://www.idatalink.com/search/search?vehicle_make_id=1&vehicle_year_id=2024&vehicle_model_id=332&vehicle_id=38176
Create a user account and get a flash cable.
You could use a Compustar system with a Blade cartridge. Something like this would work:
https://www.compustar.com/bundles/pro-csxp9900-as/?sid=30
Date Posted: September 28, 2024 at 3:29 PM
Also I was thinking about cars from the past that were manual, once I had the remote start installed I did not have to push the clutch petal in to start, this new Integra I have to still push the petal in to start so maybe that is my problem. I found the wire that I was suppose to hook up to but instead of one pink wire, there was two pink wires. How would I test that with a meter if possible? I'm looking in to the links right now that you sent me, thanks.
Date Posted: September 28, 2024 at 4:46 PM
The clutch wire will show a ground only when the clutch pedal is pressed.
Date Posted: October 05, 2024 at 8:32 AM
Thanks for the info. I couldn't get it to work and Fortin is no help so I'm gonna go with the idata one you sent me cause it seems more legit.
