Turn Pulse Output To Constant Output
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=148186
Printed Date: May 14, 2026 at 8:44 PM
Topic: Turn Pulse Output To Constant Output
Posted By: mrteausa
Subject: Turn Pulse Output To Constant Output
Date Posted: October 19, 2024 at 10:54 PM
I have alarm wire that output to horn and when trigger it will alternate on and off pulse with negative trigger. How do I convert this signal to constant trigger so I can connect to actual siren instead of horn? With the siren, I want to when alarm sound the output to constant trigger output. Is there a way to convert pulse output to constant trigger during the pulse output? I am thinking couple relays delays will do the trick but not sure how to do the wiring.
MRTEAUSA
Posted By: the12volt
Date Posted: October 19, 2024 at 11:10 PM
Posted By: mrteausa
Date Posted: October 20, 2024 at 2:05 AM
This is good to know but when you initial armed or disarmed the sound you get will be very long chirp from siren instead or short chirp siren confirmation.
MRTEAUSA
