Steering Lock After Installing Start Stop Button
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=148388
Printed Date: April 30, 2026 at 7:46 AM
Topic: Steering Lock After Installing Start Stop Button
Posted By: midomo
Subject: Steering Lock After Installing Start Stop Button
Date Posted: June 18, 2025 at 6:42 PM
Hi everyone.
Why does the steering locked after installing start - stop button with alarm, in a car does not have start stop button. What is the solution for it please. Thanks
Posted By: lee.lopez
Date Posted: June 18, 2025 at 9:54 PM
It's likely caused by some wiring not getting powered correctly. What vehicle?
Posted By: i am an idiot
Date Posted: June 18, 2025 at 10:12 PM
Probably because the steering lock is a mechanical lock that is disengaged by the key cylinder.
------------- Let's Go Brandon Brown. Congratulations on your first Xfinity Series Win. LGBFJB
Posted By: midomo
Date Posted: June 19, 2025 at 12:49 PM
Thank you for your reply guys.
@lee.lopez
it's toyota Aqua (pruis c) 2014
@i am an idiot
That is correct, I've the ignition key in and must be twisted in order to release the hatch that holding the steering wheel lock.
Si guys not sure if all cars are like this, but in this situation, I've clear visibility to the hatch that locking it and I've put something in between to stop the hatch falling abd locking the steering wheel, because if I leave the key in, then it will turn the acc on which might drain the battery. Any other professional way to get it sorted with the wiring itself?
Posted By: midomo
Date Posted: June 19, 2025 at 12:50 PM
PS if I leave the key twisted to not lock the steering wheel, then it will show an error sign like electrical error sign
Date Posted: June 20, 2025 at 7:44 AM
My old Saab I actually removed the steering column lock after it kept giving me issues.
Posted By: midomo
Date Posted: June 20, 2025 at 5:54 PM
Perfect, I might do that with most of the cars then. Thanks
Posted By: t&t tech
Date Posted: August 18, 2025 at 12:19 PM
When converting a key start car, to PTS, DISCONNECT THE IGNITION HARNESS AND KEYSENSE WIRE IF PRESENT, then simply turn on the key to acc or ignition position, the steering lock will remain unlocked.
