alarm goes off
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=15105
Printed Date: March 16, 2026 at 9:38 AM
Topic: alarm goes off
Posted By: alanleary
Subject: alarm goes off
Date Posted: June 18, 2003 at 11:22 AM
after i arm the alarm the thing oges off 20 sec later,,, and the shock sensor quit working? (NO LIGHTS ON SHOCK SENSOR) i unpluged it and still same thing...any ideas?
dogsalan1
Posted By: Powerslave0
Date Posted: June 18, 2003 at 1:22 PM
The alarm can go off for many reasons. . .
Number one, the unit just doesn't work right.
Number two, if using a voltage sense wire, something in the car clicks and causes the alarm to go off.
I have a Dodge Avenger ES, and my factory alarm ARMS 30 seconds after I lock the door. If I sit inside the car, I can hear a relay click about 15 seconds after I remove the key, so something is clicking off. NORMALLY, that probably would set the alarm off, but since it arms 30 seconds after, then it's fine.
If you haven't tried this, wait about 30 seconds before ARMING, after you exit the vehicle. Something in the electrical circuit may be setting it off. IF you only have one shock sesnor, and it was REMOVED, and it still went off, then it's either the UNIT, or sensing a current change after you arm it.
Date Posted: June 18, 2003 at 4:21 PM
IT'S the unit and the dealer is going to replace it. thank for the help  ALAN
dogsalan1
