Searching Wiring diagram for Crysler ....
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=15274
Printed Date: March 14, 2026 at 4:22 AM
Topic: Searching Wiring diagram for Crysler ....
Posted By: Bacila
Subject: Searching Wiring diagram for Crysler ....
Date Posted: June 22, 2003 at 2:09 AM
Hello Dear Members,,
I searching wiring diagram for Chrysler Voyager 1991. (i want conect  Alpha2002 security/start system on my car).
Regards Bacila
Posted By: Velocity Motors
Date Posted: June 22, 2003 at 9:16 AM
|              12V|red                 |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|dk. blue            |+  |ignition harness            |
|        ACCESSORY|BLACK/ orange        |+  |ignition harness            |
|       POWER LOCK|ORANGE / white        |+  |behind relays above fuse box|
|     POWER UNLOCK|pink/purple         |+  |behind relays above fuse box|
| PARKING LIGHTS +|BLACK / YELLOW        |   |low in drivers kick         |
| PARKING LIGHTS -|BROWN / orange        |   |at switch                   |
|       HEADLIGHTS|ORANGE / white        |-  |switch                      |
|     DOOR TRIGGER|yellow              |-  |left of steer. column       |
|  TRUNK/HATCH PIN|tan/black *2        |-  |drivers kick panel          |
|TRNK/HTCH RELEASE|GREEN/ black         |+  |at switch                   |
|       TACHOMETER|gray,RED / yel,blu/yel|   |coil pack *1                |
|       BRAKE WIRE|WHITE/ tan           |+  |brake pedal switch          |
|     HORN TRIGGER|BLACK/ red           |-  |steering column             |
|           WIPERS|RED / yellow          |+  |steering column             |
|  LF WINDOW UP/DN|lt. blu - white     |A  |in driver door              |
|  RF WINDOW UP/DN|brn/wht - pur/wht   |A  |in driver door or dkp       |
Notes:
*1 The 3.3, 3.5, and 3.8L V6 engines use a triple coil pack. Wire colors are for 2 cylinders each. The gray wire may also be gray/black.  *2 Side door is BROWN / yellow in driver's running board.
Posted By: Bacila
Date Posted: June 22, 2003 at 4:17 PM
Hello,
Thank's for support.
but maybe anybody have full servise shematic document (wiring diagram) Chrysler Voyager 1991 2.5l mono injection with full electrical (El.windows,internal computer,centrall lock,air cond. etc). I can exchange it for any thing from my products(www.bacila.tvk.lt).
P.S.:Today i instaled my Alpha 2002 in my car but i interesting other parts of my car.
Regards Bacila
