Problem with the Door locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=15334
Printed Date: March 14, 2026 at 8:46 PM
Topic: Problem with the Door locks
Posted By: keasy
Subject: Problem with the Door locks
Date Posted: June 23, 2003 at 1:44 PM
I have a 1998 Mazda MPV with an Autopage 700LCD alarm. All of the sudden the Auto door locks stop controling the driver side door.  It will lock all the doors when I arm the alarm.  But it will unlock all the door except for the drivers side when I disarm the alarm. What seems to be the problem?
Posted By: cbowery76
Date Posted: June 23, 2003 at 5:27 PM
I am having the same exact problem. Let me know if you find out.
Posted By: Velocity Motors
Date Posted: June 23, 2003 at 10:21 PM
Does the lock switch still work all the doors including the driver's door ?
Posted By: keasy
Date Posted: June 24, 2003 at 7:32 AM
Yes, when I arm the alarm it will lock all the doors.  But when I disarm the alarm it unlocks all the doors except the drivers side.
Posted By: keasy
Date Posted: June 24, 2003 at 7:36 AM
Velocity Motors, I just wanted to clearify your question.  If I do not use the alarm and just push the drivers side lock down, it will lock all the doors.  And if I pull the drivers side doorlock up, it will unlock all the doors. So, it doesnt' seem to be something with the doorlocks.  It seems to be something with the alarm.
Date Posted: June 24, 2003 at 8:05 AM
Sounds like you have a central door lock system. Here is the wiring information for the van, you will need to go into the alarm CPU harness and test the wires going to the door lock wires:
|       POWER LOCK|gray                |-  |DKP or timer below AC blower|
|     POWER UNLOCK|lt. green           |-  |DKP or timer below AC blower
You will need to use a ground wire to toggle the lock wires and see if they still only do all doors except the driver's door.
Posted By: keasy
Date Posted: June 24, 2003 at 9:13 AM
All of the sudden it works now.  There must be a loose wire somewhere.  Thanks.
