door lock relay help
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=15452
Printed Date: March 18, 2026 at 9:45 PM
Topic: door lock relay help
Posted By: jonafer
Subject: door lock relay help
Date Posted: June 25, 2003 at 7:06 PM
Hello, I have just installed a black eagle 4000 alarm in my 1993 ford mustang LX. I can not understand how to install the door lock relay's. Can anyone give me some information on this system,how old it is, do these systems still exsits? I have the alarm working fine but the relay's ???????????????  I just cant understand
thanks, jonafer
Posted By: draasch
Date Posted: June 25, 2003 at 7:52 PM
Power Lock PINK / YELLOW DRIVER KICK #203
Power Unlock PINK/LIGHT GREEN PANEL
#203- See Reversal Rest At Ground Door Lock Diagram
look to the left of this screen and go to Car Security. then go to door locks. look for Reversal Rest At Ground Door Lock Diagram. that should get you on your way.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: Mr.Swifty
Date Posted: June 26, 2003 at 6:25 PM
it is easier to grab door locks from the passenger kick panel on the Mustangs....sometimes it's hard to cut and re-connect the wires on the drivers side, ....but they will be a pink / YELLOW and pink green wire.....it's easy if you drop the glove box down, and find the grey molex plug behind a black padded cover. Just make sure when you test the wires you do it from the drivers door. otherwise you will find different wires.
Cut the wire (either lock or unlock)
put the side with 12v when you push the switch on pin 87a
put the other side on pin 30
constant FUSED power to pin 87
Constant power to 86
and negative pusle from the alarm to pin 85
do this one relay for lock one for unlock
make sure you have a fuse inline on the constant power wire. and test it out.....if the fuse blows, you have pin 87a and 30 mixed up.....if it works...put everything back together.
Good Luck
