parking lights help
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=15504
Printed Date: March 19, 2026 at 11:34 PM
Topic: parking lights help
Posted By: blkjava
Subject: parking lights help
Date Posted: June 26, 2003 at 8:41 PM
Hey guys i have a project i need help with....I want to used my factory remote entry to control a common 3 wire sensor module to sensor my car without an alarm using my horn to sound off when car is tampered with.. Example convert the -output to a +12v output that will trigger my horn to sound off... and convert my factory remote to flash the parking lights when i unlock-locks the doors and beep the horn ------------- A sabato
Posted By: auex
Date Posted: June 26, 2003 at 8:46 PM
First, what type of vehicle do you have? Does it have a factory alarm? What type of sensor are you trying to add?
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: blkjava
Date Posted: June 27, 2003 at 7:12 AM
Lincoln navigator..... no factory alarm just an anti-thief system.....a remote entry with panic button...... i want install a basic 3 wire sensor (Example pull on the doors handle or hit a window)
Posted By: profuse007
Date Posted: June 27, 2003 at 9:38 AM
let see if i can help
you can get any sensor (impact sensor) a one stage sensor is good enough. use that with a relay to break off the door trigger, hence opening the door and the horn will sound off.
Posted By: Chris Luongo
Date Posted: June 28, 2003 at 9:41 AM
You can buy inexpensive car alarms that will upgrade your keyless entry to a full-featured alarm system, with starter kill, parking lights, shock sensor, illuminated entry, and so forth.....around $50 wholesale price.
You can look on eBay for DEI's Hornet 700T. It is a half-decent unit but lacks several desirable features. The shock sensor is built into the brain, so you have to mount the brain where you can get to it for adjustments. You must buy your own starter kill relay separately. The parking light output is a low-current negative---you must buy a relay to make the high-current positive that your car requires.
At work, I use the Audiovox Pursuit PRO9232S. It has outboard shock, high-current parking lights, starter kill included, and is easy to install. I've never seen those easily purchased without install, but if you can find one it would be good.
