Take down under dash on 97 cavalier?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=15706
Printed Date: April 09, 2026 at 8:10 AM
Topic: Take down under dash on 97 cavalier?
Posted By: padawan
Subject: Take down under dash on 97 cavalier?
Date Posted: July 01, 2003 at 8:14 AM
Does anyone know how to take down the under dash panel on a 97 cavalier so I can install an alarm? Thanx.
Posted By: CutDog504
Date Posted: July 01, 2003 at 3:57 PM
I havent done a 97 Cavalier yet, but the best way to start is the same way I do every other car that I do for the first time. First look for any exposed screw, nuts or plastic clips, and undo them. Beware, some screws may be hidden by plastic plugs or cover that nedd to be popped off. After you remove all the screws or other fastners that you can find, try gently pulling down on the panel. If you feel resistance, try to see if theres any more screws that you didnt notice. Sometimes these panels are helb by metal clips and you just have to pull the panel off. But be cautious, as you dont wanna break anything by just trying to "rip" it off.
Posted By: auex
Date Posted: July 01, 2003 at 4:00 PM
You don't. You can get to all of the wiring that you need pretty much in the kickpanels of the car. The ignition harness is the large loomed harness that is to the left of the column. My recomendation is not to bother taking the underdash off.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: padawan
Date Posted: July 01, 2003 at 4:05 PM
yeah, I had already installed the alarm, but i wanted to mount it better high under the dash, I guess i'll just work with what i got and just hide wires better and find a way to mount the brain higher on the underside of dash instead of just having it wire tied to a harness like it is, maybe velcro?
Posted By: auex
Date Posted: July 01, 2003 at 6:40 PM
My suggestion would be to take the top of the dash off and put the alarm up there and run the wires down from the top of the dash. It would be pretty stealth and easy to hide the alarms wiring.
Posted By: JWorm
Date Posted: July 01, 2003 at 7:34 PM
The underdash on those vehicles does not come off. Remove the upper dash and mount it from the top as stated above. I hope you know how to take off the upper dash...its kinda tricky the first time. Open the glove box, there are a couple 7mm in there. There is a philips screw in the top center vent, along with a 7mm on the far sides behind the panels that pop off (the doors have to be open to remove the panels). Might be a couple more....I would know where if I saw the vehicle again.
Posted By: padawan
Date Posted: July 01, 2003 at 8:44 PM
yep sure do know how to take the upper dash off, installed an aftermarket head unit in that car and the top dash has to come off to put in the radio...so thanx for u guys'input.
