remote starter
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=1572
Printed Date: April 23, 2026 at 8:05 AM
Topic: remote starter
Posted By: zfshrmn
Subject: remote starter
Date Posted: June 28, 2002 at 7:44 PM
I have a question. i just install my remote starter and my car will not start If I don,t have the key in the ignition swich. ford ranger 2000 3.0 4x4
Posted By: zfshrmn
Date Posted: June 28, 2002 at 8:09 PM
ok I think I got it here is my other question. How can I do something to bypass the factory anti-theft in my ford ranger 2000 3.0?
Posted By: the12volt
Date Posted: June 28, 2002 at 8:12 PM
Hi zfshrmn, sounds you do not have 12V+ going to both Grey / YELLOW ignition leads during start. the12volt
Date Posted: June 28, 2002 at 8:14 PM
Hi zfshrmn, the factory disarm lead is Dark GREEN/ Purple in the driver's kick panel. Apply a negative pulse to this lead to disarm the factory alarm. the12volt
Posted By: zfshrmn
Date Posted: June 28, 2002 at 8:19 PM
my conetion to ignition 1 don,t keep the 12 v but the second ignition dose keep it
Date Posted: June 28, 2002 at 8:25 PM
You want the two Grey / YELLOW ignition leads to have 12V+ just before, during, and after start. When you test these leads they will show 12V+ anytime the key is in the "Run" position. the12volt
Posted By: mobiletoys2002
Date Posted: June 28, 2002 at 8:28 PM
your car should have a transponder based system in it thats why your car only satrts with the key in the ignition you will need to bypass that with a bypass module or another spare key.when you r key is in the ignition is thier a little key light that shows on your dashboard?????????
Date Posted: June 28, 2002 at 8:30 PM
you will need to take care of the transponder first  as well as the three ignitions that car has good luck.
Posted By: zfshrmn
Date Posted: June 28, 2002 at 8:35 PM
I never seen a litte key light on the dashboard but I have seen a red theft on it.
by bypassing the factory alarm will not bypass the transponder system the alarm is not keeping your car from starting it is the transponder in the factory key
Date Posted: June 28, 2002 at 8:39 PM
well what im reading says your car has a transponder in the key it will only start with that key,if you dont bypass that you will never get the remote start to work try to get a keyless bypass module for that car if not you will need to get a factory key ,,,, i know its a pain in the a## but thats how it is.
Posted By: zfshrmn
Date Posted: June 28, 2002 at 8:44 PM
ok thank you for you help Mobiletoys2002 and the12volt
Date Posted: June 28, 2002 at 8:52 PM
no problem, you are half way there  at least you know your remote start is wired right thats always good.
