2002 honda odyssey wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=15731
Printed Date: April 09, 2026 at 1:16 AM
Topic: 2002 honda odyssey wiring
Posted By: DOHOA
Subject: 2002 honda odyssey wiring
Date Posted: July 01, 2003 at 3:03 PM
I am installing alarm and remote start . Need wiring color and location. Thanks
Posted By: draasch
Date Posted: July 02, 2003 at 9:34 PM
Make:   Honda
Model: Odyssey
Year:    2002
This Database Was Last Updated On:    6/9/03
Index #: 8277
Alarm
Constant 12 volts WHITE IGNITION SWITCH HARNESS
Ignition 12 volts BLACK / YELLOW IGNITION SWITCH HARNESS
Starter BLACK/ WHITE IGNITION SWITCH HARNESS
Dome Light BLACK/ WHITE (-) 24 PIN BLUE CONN BEHIND DRIVE DASH
Trunk Pin Switch ORANGE (-) DRIVER KICK PANEL 21 PIN WHITE CONN
Parking Lamp RED / BLACK (+) 10 PIN GREEN CONN DRIVER FUSE BOX
Power Lock BLACK/ WHITE DRIVER KICK PANEL (LX MODEL) * #201
Power Unlock GREEN/ RED DRIVER KICK PANEL (LX MODEL) *
* EX MODEL:LOCK-BLACK/ ORANGE, UNLOCK-BLUE/ORANGE At 20 Pin GREEN Connector At Passenger Fuse/Relay Box In Passenger Kick Panel Negative Pulse Type #201 #201- See Negative Pulse Doorlock Circuit Diagram.
Remote Start
Tach Signal BLUE 2 PIN CONN LEFT SIDE OF ENGINE #239
Ignition #2 YELLOW IGNITION SWITCH HARNESS
Ignition #3 N/A
Accessory WHITE/ BLACK IGNITION SWITCH HARNESS
Neutral Safety GRAY (-) AT SWITCH ON TRANSMISSION *
Brake Light WHITE/ BLACK (+) SWITCH ABOVE BRAKE PEDAL
Reverse Light WHITE (-) 18 PIN GREEN CONN.DR UNDER DASH RELAY
Rear Window Defrost BROWN / YELLOW (-) BACK OF CLIMATE CONTROL PANEL (LX) **
* Also BLUE/WHITE (-) 25 Pin GREY Conn Of PCM Behind Lower Heater Cover ** EX Model:Behind Heater Control Panel #239- See Immobilizer Bypass Circuit Diagram
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
