prestige alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=15740
Printed Date: April 09, 2026 at 4:30 AM
Topic: prestige alarm
Posted By: shortie
Subject: prestige alarm
Date Posted: July 01, 2003 at 4:23 PM
need the wireing diogram for a 13 pin harniss and model # for this alarmthe only # on it is the FCC ID :ELV55AAL708R please help me thanks
Posted By: the12volt
Date Posted: July 01, 2003 at 5:17 PM
Try this: Prestige APS-25-CL Diagram  If your main harness wire colors are different, list the colors and we'll go from there.
posted_image the12volt • Support the12volt.com
Posted By: shortie
Date Posted: July 01, 2003 at 5:59 PM
the colors are as folows from left to right blue, red, white, blue/white, orange, purple, gray, black, green, yello, brown, WHITE/ black, and RED / white
Date Posted: July 01, 2003 at 6:22 PM
If your alarm is a Prestige unit, all of the wire colors you listed will be the same as those shown in the diagram I linked to above. The Blue/White doesn't sound familiar but it will likely be the normally open terminal of an internal relay where Blue is the common of the same relay. Use your meter to verify this after everything else is connected before you make any connections to the Blue and Blue/White wires. First test each lead for voltage, then for continuity to ground, then continuity with each other. Next test each of them again while activating the second channel of the alarm. If I come across a diagram showing the 13 colors you listed on the main harness I'll post it. If you bench test your unit before then, please post your results.
