2001 isuzu rodeo sport v6
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=16041
Printed Date: May 11, 2026 at 3:12 AM
Topic: 2001 isuzu rodeo sport v6
Posted By: johnnyd34
Subject: 2001 isuzu rodeo sport v6
Date Posted: July 08, 2003 at 12:24 PM
Can anyone provide me a wiring diagram for this vehicle?
i am installing an Avital Avistart 3300. Any tech notes would also be appreciated!
posted_image thank you
Posted By: draasch
Date Posted: July 09, 2003 at 7:18 PM
Make:   Isuzu
Model: Rodeo & Rodeo Sport
Year:    2001
This Database Was Last Updated On:    6/9/03
Index #: 535
Alarm
Constant 12 volts WHT/BLK OR WHT IGNITION SWITCH HARNESS
Ignition 12 volts BLK/YEL OR BLK/RED IGNITION SWITCH HARNESS
Starter BLK/WHT OR WHT/BLU IGNITION SWITCH HARNESS
Dome Light RED / GREEN (-) AT PIN 5 OF 16 PIN WHITE CONNECTOR *
Trunk Pin Switch SAME CIRCUIT AS DOME LIGHT
Parking Lamp GREEN/ RED (+) AT PIN 4 OF 19 PIN BLACK CONNECTOR *
Power Lock L GREEN/ RED AT PIN 4 OF 22 PIN WHITE ** #201
Power Unlock RED / BLUE AT PIN 12 OF 22 PIN CONNECTOR
* Connector Located In Drivers kick panel. **Rear Of Left Front Wheel (Rubber Boot Removed) Connects Body Wire Harness To Driver Door Wire Harness. #201 See Negitive Pulse Door Lock System
Remote Start
Tach Signal BLACK/ RED GREEN 16 PIN CONNECTOR *
Ignition #2
Ignition #3 BLK/RED OR BLK/YEL IGNITION SWITCH HARNESS
Accessory BLUE IGNITION SWITCH HARNESS
Neutral Safety
Brake Light RED (+) AT BRAKE SWITCH
Reverse Light RED / YELLOW (+) WHITE 16 PIN CONNECTOR *
Rear Window Defrost YELLOW /GREEN (-) 22 PIN BLACK CONNECTOR DRIVER'S KICK
* Left Side Of Engine Compartment At Top Of Fire Wall.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Date Posted: July 09, 2003 at 7:58 PM
thank you very much david from Ace Security
