adding 700t to 2003 ford expedition keyle
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=16063
Printed Date: May 11, 2026 at 5:06 PM
Topic: adding 700t to 2003 ford expedition keyle
Posted By: asiaadad
Subject: adding 700t to 2003 ford expedition keyle
Date Posted: July 08, 2003 at 6:25 PM
hello,
i would like to add the 700t to my factory keyless entry module for full alarm functions......anyone know where the keyless entry module is located and any thing that i should know about this endeavor.
thanks much
mike's alarm and radio
mike holbrook
Posted By: profuse007
Date Posted: July 08, 2003 at 6:29 PM
you dont need to locate the unit. you need to find the door lock/unlock wires which pulse the arm and disarm the alarm. that's it
you should ask this person, hes workin on the same unit
Houston,TX
Posted By: asiaadad
Date Posted: July 08, 2003 at 10:47 PM
you said just find lock and unlock......i know that you need to hook up more than just the lock and unlock to the 700t for full alarm.
any more info would be appreciated
thanks
mike
mike holbrook
Date Posted: July 09, 2003 at 10:33 AM
well the of course the power, ground and lil things, but mainly the unlock and lock which activates and deactivates it.
harness 1:
orange- is connect to a relay. i suggest doin this last.
white- parkin light(might not need it since your stock might blink)
violet- door trigger(+)
black-ground
yellow-ignition
brown-siren
red-+12v
harness 2:
green arm-lock
red disarm-passenger unlock
blue disarm-driver unlock
hope this will help this time
Houston,TX
Date Posted: July 09, 2003 at 10:39 AM
heres the diagram you might need
12V|GREEN/ purple        |+ |ignition harness
IGNITION|blue/green          |+ |ignition harness
POWER LOCK|pink / YELLOW        |- |driver kick panel|
|POWER UNLOCK|pink/green          |- |driver kick panel
|DISARM DEFEAT|pink/orange        |   |passenger kick panel
PARKING LIGHTS +|brown|   |driver kick panel
DOOR TRIGGER|BLACK/ lt. blue      |+ |driver kick panel
Houston,TX
