1999 Ford Ranger Alarm Trouble
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=16249
Printed Date: May 14, 2026 at 1:11 AM
Topic: 1999 Ford Ranger Alarm Trouble
Posted By: bcranger
Subject: 1999 Ford Ranger Alarm Trouble
Date Posted: July 13, 2003 at 1:45 PM
Recently installed Avital alarm into 99 Ranger extend cab, 4 door.  Also installed actuators and all appropriate relays etc.  Everything works fine and as expected but the alarm will go off after being armed for about 1 hour.  This occurs regardless of the shock sensor setting.
I'm guessing there has to be some sort of voltage drop or something.  Someone told me to put a 10K resistor in series with the dome light and that is should fix the problem.
Anyone else experienced this problem with rangers or is the brain maybe a junker?
Posted By: 10nesne1
Date Posted: July 13, 2003 at 2:28 PM
Most Ford vehicles have a GEM module sends a pulse to the door pins every 15 to 20 minutes and checks if the doors are closed or not. This will trigger your alarm system to false alarm. Here is a diagram will isolated the door pin trigger. This diagram will work with all newer Ford vehicles start from 99 and up.
https://www.bulldogsecurity.com/wires2/wiringimages/WINDSTAR%20DOORPINS.gif
Good luck
