2004 Toyota Sienna Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=16373
Printed Date: May 15, 2026 at 7:31 PM
Topic: 2004 Toyota Sienna Wiring
Posted By: lburrowes
Subject: 2004 Toyota Sienna Wiring
Date Posted: July 16, 2003 at 12:15 PM
Does anyone know where I can obtain the wiring codes for this vehicle?
Posted By: Chris Luongo
Date Posted: July 17, 2003 at 7:15 PM
You could do a search.
Posted By: 10nesne1
Date Posted: July 18, 2003 at 3:33 PM
Here are the wirings:
PASSIVE ANTI-THEFT YES TRANSPONDER SEE NOTES
12 VOLTS    WHITE/ red    Ignition switch harness +
IGNITION    Black        Ignition switch harness +
IGNITION 2 BLACK / YELLOW (small gauge)   Ignition switch harness +
ACCESSORY   Pink        Ignition switch harness +
STARTER     BLACK / YELLOW (large gauge)   Ignition switch harness +
TACH      Use an injector
LOCK      Green      In driver's kickpanel -
UNLOCK    Blue (double pulse)    In driver's kickpanel -
RIGHT SLIDING DOOR CONTROL     PURPLE / w. brown dots    In large harness on top of fusebox -
FACTORY ARM       Arms with lock wire
FACTORY DISARM    Disarms with unlock wire
BRAKESWITCH     GREEN / WHITE      Center plug on front of fusebox +
PARKLIGHTS     GREEN/ black    At light switch harness -
Vehicle notes
PLEASE NOTE: This vehicle is equipped with a TRANSPONDER passive anti-theft system. A keyless bypass module may be available, contact your supplier to find out. If one is not available to you, please refer to the appropriate security diagram for bypass information.
Good luck
