555H Bypass Help
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=16562
Printed Date: April 02, 2026 at 6:46 AM
Topic: 555H Bypass Help
Posted By: undergraduate
Subject: 555H Bypass Help
Date Posted: July 22, 2003 at 8:29 AM
I just installed a crimestopper cs2015 system on an 02 Accord and everything works fine, but I can't seem to get the bypass to program. The led will come, but will never go out and I have tried three different keys. Is there something special I need to do that I don't know about?
Posted By: Velocity Motors
Date Posted: July 22, 2003 at 8:36 AM
Seems that other people are having alot of trouble as well with the 555H. Take the module back to the place that you got it and try another one. We use PKH2 and we have never had any problems with their products learning a code.
------------- Jeff
Date Posted: July 22, 2003 at 8:40 AM
Taking it back is not really an option, I need to make it work.
Date Posted: July 22, 2003 at 3:10 PM
Ok, I got it. Instead of having the ground when remote starting connected to the bypass, connect it to a ground to program it and then connect it to the ground when remote starting after it is programed.
