pop truck feature
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=16801
Printed Date: March 14, 2026 at 2:51 AM
Topic: pop truck feature
Posted By: daslabb
Subject: pop truck feature
Date Posted: July 28, 2003 at 6:58 PM
How do u wire up the truck release on alarms.Does it involve an relay.
Posted By: ViperATC5
Date Posted: July 28, 2003 at 7:42 PM
Last time i checked they were called trunks, and yes some applications need a relay. Please provide the make, model, and year of the vehicle so we can be of further assistance.
Basically, you use the alarms aux channel to drive a relay to pop the trunk, assuming that your vehicle is equipped with a power trunk release. If the car only has a lever, you would need to use a trunk pop solenoid.
Posted By: draasch
Date Posted: July 28, 2003 at 8:35 PM
what is the yr make and model of your car??? also what brand of unit are you using???
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: daslabb
Date Posted: July 29, 2003 at 4:36 AM
92 buick roadmaster.perfomace teknique ICBM-7071
Posted By: draasch
Date Posted: July 29, 2003 at 5:03 AM
Trunk Pin Switch DARK GREEN (-) AT TAILGATE AJAR SWITCH (WAGON ONLY)
im not sure what the output is for that alarm but the wire is a neg. wire
Good Luck
David
Ace Security
813-376-9778
Tampa
Posted By: daslabb
Date Posted: July 29, 2003 at 5:59 PM
what r the door lock types for an 95 isuzu rodeo and 92 buick roadmaster.
Posted By: draasch
Date Posted: July 30, 2003 at 11:57 AM
This is for the buick
Power Lock LIGHT BLUE AT RELAYS IN DRIVER KICK PANEL # 202
Power Unlock BLACK AT RELAYS IN DRIVER KICK PANEL # 202
#202- See Positive Pulse Door Lock Diagram
Good Luck
David
Ace Security
813-376-9778
Tampa
