RS750-LCD + proximity help
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=17055
Printed Date: May 15, 2026 at 3:42 PM
Topic: RS750-LCD + proximity help
Posted By: TheevesLLC
Subject: RS750-LCD + proximity help
Date Posted: August 02, 2003 at 2:18 PM
hi, i successfully installed my rs750 almost 6mo ago, and everything works fine... i've lost some of the manuals now, and i'm trying to install a proximity sensor because i'm always leaving the roof off... the one manual i could find refers to it as the PIR-750 sensor, but i purchased a non autopage unit.  anyway, the manual tells me how to configure it, but nowhere in the diagrams can i see where to wire it in, and when i installed it i taped up these huge service loops.  i don't want to take them out until i know what i'm doing, cuz it's a huge mess in there!
anybody have any suggestions?
Posted By: draasch
Date Posted: August 02, 2003 at 2:23 PM
does sensor has 3-4 wires???
if so you shouls have a red-12v
blue-neg trigger
green-prewarn
blk-ground
if you dont have a sensor ort to plug into, you can just hardwire it up.
you try to search on line for the alarm info.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Date Posted: August 02, 2003 at 10:20 PM
ok, i just removed the plug for the shock sensor, crossed some wires on the prox harness, and am using it through that... is there any way i can hook them both up thru the one input?  i would have to transistorize the connection.  is that a good idea?  or should i just leave it, i don't really need a shock sensor if i have a prox sensor right?
thx
Posted By: draasch
Date Posted: August 02, 2003 at 10:26 PM
its up to u. u might have probs. with bad storms
Good Luck
David
Ace Security
813-376-9778
Tampa
