2000 Lincoln LS
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=17088
Printed Date: May 15, 2026 at 7:01 AM
Topic: 2000 Lincoln LS
Posted By: kidtransam
Subject: 2000 Lincoln LS
Date Posted: August 03, 2003 at 11:15 AM
Installin a hornet 554t (2way) on a 2000 Lincoln LS..techsoft says `This wire may cause the aftermarket alarm to false when the vehicles electrical system shuts down. Use a relay to isolate it.`
I`ve never had the need to do this..Could you guys give me the relay hook up to accomplish this?
Thanx
With a torch and a big enough hammer...it WILL friggin fit!!
Posted By: draasch
Date Posted: August 06, 2003 at 8:21 AM
WHAT WIRE ARE YOU TALKING ABOUT?????
Make:   Lincoln
Model: LS
Year:    2000
This Database Was Last Updated On:    6/9/03
Index #: 7856
Alarm
Constant 12 volts RED & RED / GREEN IGNITION SWITCH HARNESS
Ignition 12 volts GREEN/ BLACK IGNITION SWITCH HARNESS
Starter GRAY/BLACK IGNITION SWITCH HARNESS
Dome Light SEE NOTES * INDEPENDANT DOOR TRIGGER *
Trunk Pin Switch WHITE/ BLACK (-) REAR ELECTRONIC MODULE **
Parking Lamp WHITE/ GREEN *** AT HEADLIGHT SWITCH (RESISTOR SYSTEM)
Power Lock WHITE/ BLACK DRIVER DOOR MODULE
Power Unlock WHITE/ VIOLET IN DRIVER DOOR #201
* Must Diode Isolate Door Triggers For Each Door. Front Dr. BLK/YEL Pass. BLK/BLU At Front Elect Module In Driver Door. Rear Dr. BLK/ORG Pass. BLK/GRN At Rear Elect Module In Trunk. ** Rear Electronic Module Located In Passenger Side Of The Trunk. *** See TECH NOTES For Relay Pin Out And Resistor Value. #201- See Negative Pulse Door Lock Diagram.
***This Vehicle Has A Resistered Park Light System. The WHITE/ GREEN Wire Must Be Cut And A Relay And Resistor Must Be Used. Pin 85 GROUND, Pin 86 WHITE Wire Of Alarm, Pin 87A Switch Side Of WHT/GRN Wire Pin 30 BCM Side Of WHT/GRN Wire. Pin 87 One Side Of A 1780 Ohm Resister, The Other Side Of The Resister To Ground. If Park Lights And Head Lights Are Required Use A 780 Ohm Resister In Place Of The 1780 Ohm Resister
give us more info
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
