Alarm - Remote Start Help on Dodge Carava
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=17100
Printed Date: May 15, 2026 at 2:43 AM
Topic: Alarm - Remote Start Help on Dodge Carava
Posted By: sgoldschmidtii
Subject: Alarm - Remote Start Help on Dodge Carava
Date Posted: August 03, 2003 at 4:07 PM
Hello, I have a Dodge Caravan 2002 Sport and I am trying to install a Sidewinder 6500ESP Alarm Remote Start. I am having problems getting the car to start when i have the Second Starter connect ( it has a negative output). According to DEI I need to veiw the following documents - DirectFax Document #1083 and DirectFax Document #1082. Can anyone help me figure out the wiring or can anyone send these documents. Thank you,
Posted By: 1990caddy
Date Posted: August 03, 2003 at 7:54 PM
Does it turn over with the remote start? Because if it doesnt, if I am not mistaken Chrysler products, like GM have some sort of starter disable, so that you can't start the car without the key. I just went through the same thing with my Caddy. Anyway, they might make a by pass kit for your car, thats all I can think of.
Date Posted: August 03, 2003 at 8:17 PM
I have the 555U from viper which is the key bypass. What I am having problems with is the second starter wire on the car is a - (negative) output not positive. And according to the wire diagram i need to some how use a relay to change the polarity or something from + (positive) to - (negative). I already used a relay with a 180 ohm resitor on it and my car cranks but doesn't turn over even with the key. When i disconnect the connection i have made then it works fine. This is why I am asking if anyone has the Direct Fax Documents #1082 and 1083 available, so that i can see how this car needs to be wired to the second starter.
Posted By: ViperATC5
Date Posted: August 03, 2003 at 8:45 PM
Hopefully these links will work for you:
https://www.directechs.com/techtips/pdfs/resources/security/directed_techtips/1082.pdf
https://www.directechs.com/techtips/pdfs/resources/security/directed_techtips/1083.pdf
Date Posted: August 04, 2003 at 6:47 AM
Thank you so much ViperATC5. These should work out fine.
