2001 suzuki xl-7
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=17167
Printed Date: May 14, 2026 at 12:29 PM
Topic: 2001 suzuki xl-7
Posted By: hardplay
Subject: 2001 suzuki xl-7
Date Posted: August 04, 2003 at 11:20 PM
Any one done a 2001 SUZUKI XL-7 remote start and alarm? I am looking for the wire diagram and color codes
Posted By: 10nesne1
Date Posted: August 05, 2003 at 10:12 AM
Installed an alarm on this vehicle and is pretty easy, but didn't installed the starter. Everything is on the driver's side dash and kick panel.    Good luck.
Suzuki
XL-7
2001-2002
Remote Starter Wiring Colors and Notes
Function   Vehicle Color      Location
Start:     WHITE/ Red          Ignition Switch Harness*
Ignition #1:   BLACK/ Blue     Ignition Switch Harness
Ignition #2:   Blue/Black     Ignition Switch Harness
Ignition #3:   Yellow/Black Ignition Switch Harness****
Accessory:     Blue          Ignition Switch Harness
Brake Light:   GREEN / WHITE (+)   At Brake Switch
Tach Signal:   Brown   At PCM** or Instrument Cluster
Parking Lights:   RED / Yellow     Drivers Kick Panel
Headlights:     Gray/Black (-)    At Headlight Switch
OEM Alarm Disarm:   No Color Available Please call with information
OEM Alarm Arm:   No Color Available   Please call with information
Diesel Glow Plug:   N/A
Clutch Bypass Wire:   No Color Available Please call with information
Notes:
   *Vehicle may have an anti-theft system. No Data Available! **PCM Located behind glove box. ****All DesignTech remote starters except the 2xx22 have an ignition 3 output - it is the WHITE/ black in the 'control harness.' This wire MUST(!) be used to control a relay which will power the vehicle ignition 3.
Suzuki
XL-7
2001-2002
Alarm and Keyless Entry Wiring Colors and Notes
Constant +12 Volts: WHITE/ Green Ignition Switch Harness
Starter Kill:   WHITE/ Red   Ignition Switch Harness*
Ignition +12 Volts:   BLACK/ Blue Ignition Switch Harness
Dome Lights/Superv:   BLACK/ Red   At OEM Keyless*
OEM Horn:      Blue/Green(-)      At OEM Keyless**
Power Lock:   Pink               At OEM Keyless*
Power Unlock:   Pink/Green       At OEM Keyless*
Trunk Release:   No Color Available Please call with information
Alarm Input Wire:   BLACK/ Red    At OEM Keyless*
Notes:
*OEM Keyless module located above drivers kick panel. Requires Doubel Pulse for unlock - program DesignTech module for double pulse locks or see Note #231 **Horn Connection at other locations is not recommended.
