How to Test Shock Sensor
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=17175
Printed Date: May 14, 2026 at 8:15 AM
Topic: How to Test Shock Sensor
Posted By: Creator_11
Subject: How to Test Shock Sensor
Date Posted: August 05, 2003 at 9:21 AM
Ok i hooked ym shock sensor up to my alarm, armed it, and waited 5 min then lightly lappted it, and not reaction, i then adjusted the sensitivity to max, and did the same thing again, and till no response, there two leds on the shock sensor and neither one is lit, is there a way to test my shock sensor to see if it works, i.e. hoot it up to a 12volt battery to see if it powers up, i need to find out if its my shock sensor that faulkty or the alarm brain, because during disarm, the red wire coming from the alarm sensor plug, shows abvout 5 volts, but drops to 0 when the alrm is active.
Its a 4 wire dual stage autopage shock sensor, any suggestions.
Posted By: draasch
Date Posted: August 06, 2003 at 8:12 AM
how do you have it hooked up to the alarm???
red is power
blk is ground
blue is a neg trigger
green pre-warm chirp
does this sound about right????
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Date Posted: August 06, 2003 at 3:31 PM
red is power
blk is ground
Yes that is correct!!!
So what can i do?
