Help: audiovox transmitter doesnt work
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=17298
Printed Date: May 15, 2026 at 2:28 PM
Topic: Help: audiovox transmitter doesnt work
Posted By: legend9
Subject: Help: audiovox transmitter doesnt work
Date Posted: August 07, 2003 at 7:24 PM
Hi all,
My audiovox ASP ( or APS) 785 prestige alarm transmitter doesn't work. I think it lost all the codes with my alarm, because it ran out battery for a few weeks, before I installed another one in, so I got it somewhere got reseted. Right now, I cannot use it to turn on the alarm or off the alarm, strange. Any idea?
Made in Japan
Posted By: LAUR
Date Posted: August 08, 2003 at 3:05 PM
your alarm might lost all the remots .It has to learn it again.
you must have the program manual.
Posted By: lalur
Date Posted: August 08, 2003 at 5:32 PM
all u have to do to program the remote is turn the key on hit the valet button 3x then hit the arm/disarm button on the remote then turn the key pff it should work
Posted By: legend9
Date Posted: August 15, 2003 at 8:05 PM
HI, thanks for the reply. HOw can I program the remote start? I can do the unlock , lock buttons, but I don't know how to make the starter button to work.
Made in Japan
Posted By: Chris Luongo
Date Posted: August 16, 2003 at 10:18 AM
1. key on.
2. press and release valet switch three times.
3. press lock button.
4. valet switch once.
5. press unlock button.
6. valet switch once.
7. press remote start button.
8. valet switch once.
9. press option button.
10. key off.
Posted By: legend9
Date Posted: August 16, 2003 at 8:20 PM
Much thanks, I will try this tomorrow. posted_image
Made in Japan
Posted By: legend9
Date Posted: August 19, 2003 at 1:08 PM
Hi, I've tried that. It works fine, except the remote start. When I reprogrammed it, and pressed it twice, it does nothing except chirps. It will not remote start. AM I doing something wrong ?
Made in Japan
Date Posted: August 21, 2003 at 3:00 PM
Well, it depends on what kind of chirps.
Those units have a feature where they can make a small chirp before remote starting----some installers leave it on; some turn it off-----did your unit do that before?
If it's making the chirps that say "i'm about to remote start," and then the car doesn't start, there is definitely a problem---if you had a shop install it for you, have them find the problem and fix it.
But if it's making some regular-sounding chirps, you have probably made a mistake in programming. Maybe you programmed it as a lock or unlock button?
