alarm installation problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=17355
Printed Date: April 01, 2026 at 9:32 AM
Topic: alarm installation problem
Posted By: digger33163
Subject: alarm installation problem
Date Posted: August 08, 2003 at 4:14 PM
I installed a code alarm with keyless entry. I have power windows and locks but not keyless entry. The alarm part works fine but i can only get the keyless entry to work for one door. I tried wiring each door seperate and the one not wired wouldnt work. Then i wired them both up assuming i dont have a master door and only one side worked again. This is all being done in a 2001 v-6 ext. cab tacoma. Any ideas what the problem could be? The installers even couldnt come up with any idea.
Posted By: elrayodesinaloa
Date Posted: August 08, 2003 at 5:14 PM
I believe the lock/unlock wires are on the driver's kick panel on the 12 pin connector, the wires should be RED / white for lock and RED / yellow for unlock. Also, make sure to test with the doors closed.
Date Posted: August 08, 2003 at 7:49 PM
anybody else know anything that could be the problem. Im gonna check the whole thing again in a few days. Does anybody know if a 2001 toyota tacoma ext. cab v6 has a master door?
Posted By: ViperATC5
Date Posted: August 08, 2003 at 8:23 PM
Here is the information for your vehicle:
| POWER LOCK|gray *1 |- |white plug near fusebox |
| POWER UNLOCK|purple *1 |- |white plug near fusebox
*1 These wires will test only by operating the key in the passenger door lock cylinder, not the rocker switch on the door.
