Relay w/Flasher to Honk Horn
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=1737
Printed Date: April 25, 2026 at 12:23 PM
Topic: Relay w/Flasher to Honk Horn
Posted By: INTREPID
Subject: Relay w/Flasher to Honk Horn
Date Posted: July 06, 2002 at 1:17 PM
ok when wiring a relay and flasher to honk the horn with the siren going off, do i come off the siren output to the flasher or to the relay?
also, can someone post a diagram.
thanks
Posted By: INTREPID
Date Posted: July 06, 2002 at 4:43 PM
hey mobile,
i tried the diagram and what its seem to be doing is bypassing the flasher!
any ideas?
Posted By: INTREPID
Date Posted: July 06, 2002 at 7:03 PM
YEAH THE HORN CONSTANTLY GOES OFF!
Posted By: mobiletoys2002
Date Posted: July 07, 2002 at 11:48 AM
https://howstuffworks.com/turn-signal2.htm check this out for mor einfo on how flashers work and this will explain the problem why your horn stays on all the time.posted_image
Date Posted: July 07, 2002 at 11:59 AM
you have to complete the circuit in order to make the flasher flash that is what your blinkers do that is why they flash .the horn is not completing the circuit for the flasher to get rid of the current so it will act like it is not even there. and this is why your horn stays constant, the flasher has to see a completed circuit for it to operate correctly or it will just send voltage  through it and not pulse the horn. I have not played with flashers that much so im learning a little more as well about thier operation. Maybe someone can give us some ideas about this .
Date Posted: July 07, 2002 at 12:03 PM
from what i understand your horn would have to have a positive and a negative for this flasher to work . But i did figure a way out for this to work with two relays and the flasher,but it still will not give you exactly what you want thats the problem.
Posted By: the12volt
Date Posted: July 07, 2002 at 12:39 PM
Instead of trying to use the output of the flasher on the horn's relay negative coil lead from the switch, go to the relay's positive output or directly to the horn's positive lead (at the horn). The horn's negative lead should already be connected to ground. You can use this diagram for adding light flash and instead of connecting to your lights, connect the output of the flasher to the positive lead of your horn.
