Multi Meter VS Test Light Help
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=17680
Printed Date: May 14, 2026 at 10:44 PM
Topic: Multi Meter VS Test Light Help
Posted By: Audio Heaven
Subject: Multi Meter VS Test Light Help
Date Posted: August 16, 2003 at 3:25 PM
Hi,
I have a question. When testing wires for car alarms and remote starters which is better to use a Multi Meter or a Test Light?
The test light is Weakon SST which has both power and ground testing capabilities and is run off 12v either from the cig lighter or the battery
I am confused
Posted By: anonymous
Date Posted: August 16, 2003 at 3:37 PM
A DMM will always be better than a test light even if it is "computer friendly". Just for fun plug your test light into a cig lighter and use a multimeter to test both voltage at the tip, and also resistance to ground from the tip.
Happy metering
Anonymous
Posted By: benjaminthe1st
Date Posted: August 17, 2003 at 2:35 AM
concour with Anon, not all airbag wires are shielded in yellow tubing.  A DMM or digital multimeter is the only safe way to do probe wires.  A lightmeter even one deamed safe isn't, nor is a analog multi-meter.
Discount Car Stereo
23446 Pac Hwy Kent, WA 98032
206.824.5875
Resonant Engineering, Orion, Planet Audio, Soundstream, Panasonic, Pioneer, Rockford Fosgate, Compustar, DEI,Toucan, Matrix Other lines
