2002 Mitsu Montero Sport
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=17836
Printed Date: March 30, 2026 at 6:18 PM
Topic: 2002 Mitsu Montero Sport
Posted By: vtec16
Subject: 2002 Mitsu Montero Sport
Date Posted: August 19, 2003 at 11:15 PM
Looking to install a LCD pager remote start alarm system. Need wiring diagram and any related diagrams to aid install. Any help appreciated, Thanks
Posted By: draasch
Date Posted: August 21, 2003 at 7:39 PM
Make:   Mitsubishi
Model: Montero Sport
Year:    2001-02
This Database Was Last Updated On:    6/9/03
Index #: 996
Alarm
Constant 12 volts WHITE IGNITION SWITCH HARNESS
Ignition 12 volts BLACK/ WHITE IGNITION SWITCH HARNESS
Starter BK/YELL OR BK/BLU IGNITION SWITCH HARNESS
Dome Light GREEN/ RED (-) TOP OF FUSE BOX IN A TWO PIN PLUG *
Trunk Pin Switch SAME AS DOOR
Parking Lamp GREEN / WHITE (+) AT PARKING LIGHT SWITCH
Power Lock BLACK/ RED AT FUSE #201
Power Unlock BLCK/BLUE BOX
* Also Found In Drivers (A) Piller. ** Caution On Door Locks: If Cycled Repeatly The Siloids Will Lock Up. #201- See Negative Pulse Door Lock Diagram
Remote Start
Tach Signal WHT/BLK OR WHT AT IGN CONTROL MODULE OR COIL *
Ignition #2 BLUE/RED IGNITION SWITCH HARNESS ** #239
Ignition #3
Accessory BLUE IGNITION SWITCH HARNESS
Neutral Safety
Brake Light GREEN (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light RED / BLUE (+) DRIVER KICK PANEL
Rear Window Defrost
* On 2.4L,Tach is WHT/BLK at the coil on left front of the engine compartment On 3.0l and 3.5l WHITE At The Ignition Module Next To The Coils On The Right Rear Side Of The Engine Compartment Under The Plastic Motor Cover. ** Some Modules Have The Immobilizer System. See Note #239 To By Pass
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
