99 Miata Door Lock Question
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=18381
Printed Date: May 16, 2026 at 5:19 AM
Topic: 99 Miata Door Lock Question
Posted By: Sambroak
Subject: 99 Miata Door Lock Question
Date Posted: September 02, 2003 at 10:22 AM
I have recently installed an Alpine 150R and installed it in my wifes miata.  I have everything working just like it should with the exception of the door locks.  I have the same alarm installed on my 2002 B-3000 and I had added aftermarket power door lock actuators, so they were no problem to install, but with the miata if you manually lock the drivers side door it locks the passenger side also.  My question is what controls the locking and unlocking?  I was going to take the drivers door cover off, but the person who owned the car before me has stripped the screw and I can't get the door cover off.  I am hoping that there is a wire that I can tap into to use for the lock/unlock for the alarm.  If anyone knows where a relay or wire is that I can tap into I would greatly appreciate it.
Thanks in advance
D Sambroak
Charleston, SC
Posted By: Velocity Motors
Date Posted: September 02, 2003 at 10:33 AM
The Miata uses a central door locking system taht you will need to add a single actuator ( on either the driver's side or passenger side { as long as this holds true for the passenger side controling the driver side } ) on the locking mechanism.
Posted By: Sambroak
Date Posted: September 02, 2003 at 10:44 AM
Thanks for the quick post, and the information.
It does not hold true.  If I unlock the passenger door from outside it only unlocks the passenger side.  So now I am guessing that I will need to add an actuator to the drivers door so that it will unlock both of them.
Date Posted: September 02, 2003 at 10:47 AM
Yup. You have to drill out the screw and get the door panel off the install the actuator.
Posted By: Sambroak
Date Posted: September 02, 2003 at 11:36 AM
Once again, thanks for the information, will post again when i get everything completed.
