Starter Kill Is Not Working Correctly
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=18479
Printed Date: May 16, 2026 at 10:17 AM
Topic: Starter Kill Is Not Working Correctly
Posted By: back2life
Subject: Starter Kill Is Not Working Correctly
Date Posted: September 04, 2003 at 1:28 PM
My stater kill on my alarm is doing the exacty opposite of what it is suppose to do, i was working fine now when you arm it will start when you disarm it wont. I have a Avital Phoneix 2 alarm what could be the problem, I believe it is the relay, but two head are better that one so can someone please help
Posted By: profuse007
Date Posted: September 04, 2003 at 6:19 PM
you should test the ground-if-arm wire. from there you can decide if the prob come from relay or the unit.
hope this help
Houston,TX
Posted By: brianh
Date Posted: September 04, 2003 at 7:53 PM
Sounds like you might of used a relay that doesnt have the N.C contact on it,or you hooked the wires to the N.O contact. Double check and make sure that pin 85 goes to 12 volts. Pin 86 goes to ground out when armed. Pin 87a goes to switch side of starter wire,and pin 30 goes to the starter. Hope this helps some. Good luck with it!
Brian
owner/installer
Sight & Sound Car Stereo
"all electronic equipment runs off of smoke, once you let it out, it stops working"
Posted By: floaterr
Date Posted: September 05, 2003 at 8:45 AM
I thought he said it "was working" so what made it chage.
Posted By: CutDog504
Date Posted: September 06, 2003 at 1:42 AM
dam, spooky sh*t going on right there buddyposted_image
