98 mustang diagram?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=18496
Printed Date: May 16, 2026 at 6:10 AM
Topic: 98 mustang diagram?
Posted By: lathan
Subject: 98 mustang diagram?
Date Posted: September 04, 2003 at 8:10 PM
whats up fellas?
got a quick question... is the 2000 mustang diagram listed here on this website compatible with my 98 mustang? doing my first alarm install and am a little nervous. I purchased a Carbine 5500+ alarm that should work well with my keyless entry, trunk pop, and panic buttons. I dont want to get in over my head but i would also love to add a window module that i can roll the windows down and up all with the same control for the alarm. but for now I will settle with just getting this thing installed! can anybody help me? thanks   lathan
Lathan Hites
"I'm sorry, without a credit card I'll be requiring a stool sample"
Posted By: lathan
Date Posted: September 04, 2003 at 8:16 PM
also, when I do go to start this should I just wire everything right at the drivers kickpanel where all the wires seem to be or what?or do i need to wire to the locks directly?-etc.?
i know nothing about relays and diodes but really want to learn. unfortunatly do not have the funds to go to mobile dynamics like I would love to do. Where can i learn about this stuff in a language that I can understand?
Lathan Hites
Posted By: draasch
Date Posted: September 05, 2003 at 10:33 PM
Make:   Ford
Model: Mustang
Year:    1998
This Database Was Last Updated On:    6/9/03
Index #: 5143
Alarm
Constant 12 volts YELLOW (5) IGNITION SWITCH HARNESS
Ignition 12 volts TAN/WHITE IGNITION SWITCH HARNESS
Starter WHITE/ PINK IGNITION SWITCH HARNESS
Dome Light BLACK/ L BLUE (+) DRIVER KICK PANEL *
Trunk Pin Switch BLACK/ PINK (+) AT LIGHT IN TRUNK
Parking Lamp BROWN (+) AT HEADLIGHT SWITCH
Power Lock PINK / YELLOW EITHER KICK #203
Power Unlock PINK/L GREEN PANEL ** #201
* With OEM Keyless Entry Dome Light Wire Is GRAY (+) In Driver Kick Panel. With Or Without OEM Keyless Entry Dome Light Circuit Can Also Be Accessed At Headlight Switch. ** With OEM Keyless See Note #201, Without OEM Keyless See Note #203. #201- See Negative Pulse Door Lock Diagram. #203- See Reversal Rest At Ground Door Lock Diagram.
Remote Start
Tach Signal ORANGE / WHITE AT POWERTRAIN CONTROL MODULE * #239
Ignition #2 GRAY / YELLOW (2) IGNITION SWITCH HARNESS **
Ignition #3 GRAY / YELLOW IGNITION SWITCH HARNESS **
Accessory BLACK/ L GREEN IGNITION SWITCH HARNESS ** #235
Neutral Safety NOT GROUNDING TYPE - OEM SWITCH OPENS STARTER CIRCUIT
Brake Light RED / L GREEN (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light BLACK/ PINK (+) AT SWITCH ON TRANSMISSION
Rear Window Defrost BROWN / L BLUE (+) AT REAR WINDOW DEFOGGER SWITCH
* Powertrain Control Module Is Located In Passenger Kick Panel. ** Two Of The Three GRAY / YELLOW Wires Present At The Ignition Switch Are The Same Circuit. Please Refer To TECH NOTES For Additional Information On Ignition Switch Layout. #235 - See Powering Additional Ignitions Diagram. #239 - See Immobilizer By-Pass Diagram.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
