Tach wire Location
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=18575
Printed Date: May 15, 2026 at 2:43 PM
Topic: Tach wire Location
Posted By: Darksyde
Subject: Tach wire Location
Date Posted: September 06, 2003 at 5:45 PM
I have a 97 astro van And i hooked up the tach wire to the recommended wire and nothing. What is the right color and location of the tach wire
Posted By: 10nesne1
Date Posted: September 06, 2003 at 9:40 PM
97 Astro Van has a White wire at the coil. Most GM vehicle has the White wire at the Coil.
TACH SENSOR WHITE @ COIL
Does your alarm/starter need to program the tach wire on it? Most alarm/starter required to program it to the alarm/starter when you connected it to the alarm brain.
Good luck.
