Decreasing Voltage
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=18576
Printed Date: May 15, 2026 at 1:47 PM
Topic: Decreasing Voltage
Posted By: Coomer
Subject: Decreasing Voltage
Date Posted: September 06, 2003 at 5:49 PM
Hello,
I'm currently working on something where I only want to have about 50% power or so going to my high beam headlight bulbs when my low beams are on, and I know how to wire up all the relays and everything. I'm just not sure how to reduce voltage from 12 volts down to less voltage, in order to run the lights at about 50% power. Does anyone know how to do this?
Posted By: floaterr
Date Posted: September 08, 2003 at 10:04 AM
Search the internet for a DRL system. This could give you close to what you are looking for. Also there are kits that allow you to run both sets of lights at the same time and mightcut the brightness down.
parts-express.com
performanceproducts.com
these might have it.
Posted By: Coomer
Date Posted: September 08, 2003 at 10:40 AM
So is there not really a fairly easy way to decrease voltage? I thought about using diodes, but I didn't see any diodes that can handle as much power as will be flowing through a wire for a high beam headlight.
Posted By: Coomer
Date Posted: September 08, 2003 at 10:44 AM
Would something like what's on this page work?
Posted By: floaterr
Date Posted: September 08, 2003 at 1:23 PM
jc whitney is another website.
The units I have seen have big heatsinks on them.
https://www.commandoalarms.com/itm100035.htm
Here, exactly what you are looking for and from a website that many here get car alarms from.
Posted By: Coomer
Date Posted: September 08, 2003 at 5:59 PM
Thank you for the link and the help. I just found this link, which describes how to make your own DRL system, and has the information I need in order to do this, so I'm going to try making my own system soon. :)
