Window Module questions
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=18806
Printed Date: May 15, 2026 at 8:12 AM
Topic: Window Module questions
Posted By: bhawkins
Subject: Window Module questions
Date Posted: September 11, 2003 at 6:57 PM
I recently put window modules(up and down) in my 95 Monte Carlo and I was reading the addendum in the instruction manual and it said something about rest at neutral. I did like they said and tested the switch and it gave out the 12 volts and according to this piece of paper stuck in the box, 12 volts at the switch means that I have rest at neutral. My local store did not have enough relays at the time so I decided to hook it up anyway to the window motor that needs to be replaced and to my surprise it worked without the extra relays, so I hooked up the other window and they work. I don't know if this is going to mess up any thing in the long run or did i just miss read the instructions and what does rest at neutral mean anyways?
I would prefer not to rewire the thing all over again but if it is absolutely necessary I will, and if I do could you please tell me how I need to wire the relays.
The window modules are the Bulldog security CL200. I one of them wired to EXT2 and the other on EXT3 on an Alpine SEC-150R
Thank You in Advance
Brian Hawkins
Posted By: auex
Date Posted: September 11, 2003 at 7:00 PM
There are different types of windows. For your chevy, it is a rest at ground type.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: bhawkins
Date Posted: September 11, 2003 at 7:04 PM
So good i do not need to do anything more.
Thank you so much
Brian
Posted By: cpgoose
Date Posted: September 12, 2003 at 6:45 AM
You can also give Bulldog tech support a call...they're usually pretty good. 800-878-8007. Just as a double check.
Q: What's the best nation in the world?
A: Donation!     Donate to the12volt.com
