Need help w/ esp 1500 in ’03 range rover
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=18970
Printed Date: March 27, 2026 at 9:30 PM
Topic: Need help w/ esp 1500 in ’03 range rover
Posted By: ICKSTER40
Subject: Need help w/ esp 1500 in ’03 range rover
Date Posted: September 17, 2003 at 8:42 PM
Does anyone know how to hook up the transponder to this vehicle, I've had people tell me it can't be done. any info would be usefull. thanks
DJ,Scottsdale Extreme Sound
Posted By: autosound
Date Posted: September 18, 2003 at 3:15 PM
What do you need the transponder to do,,,more info please
Posted By: zargon
Date Posted: September 18, 2003 at 4:55 PM
the tech sheets i lookd up only go to a 96, if the people telling you it can't be done are from a shop the does a lot of high dollar installs then it may not be possible, but there are not a lot of cars that can't be done.
Posted By: jayts95
Date Posted: September 18, 2003 at 7:27 PM
here is the info for an 01 range rover
hope that it helps     POWER UNLOCK|same wire           |   |                            |
|       LOCK MOTOR|ORANGE / black        |   |in driver door @ door module|
|     UNLOCK MOTOR|pink/black          |   |in driver door @ door module|
|    DISARM DEFEAT|orange              |   |LR door harness             |
| PARKING LIGHTS +|use negative wire   |   |                            |
| PARKING LIGHTS -|ORANGE / red          |   |headlight switch            |
|       HEADLIGHTS|blue               |- |headlight switch            |
|     DOOR TRIGGER|PURPLE / red          |- |BECM under pass seat        |
| DOME SUPERVISION|use door trigger    |   |                            |
| TRUNK/HATCH PIN|pur/yel or white    |- |BECM under pass seat        |
|        HOOD PIN|PURPLE / white        |- |BECM under pass seat        |
|TRNK/HTCH RELEASE|white *1            |- |tailgate unlock switch      |
| FCTRY ALARM ARM|blue/red *2        |- |in driver door @ door module|
|FCTRY ALRM DISARM|same wire           |   |                            |
|       TACHOMETER|NOT white           |   |either ignition coil pack   |
|      SPEED SENSE|                    |   |                            |
|       BRAKE WIRE|GREEN/ purple        |+ |brake pedal switch          |
|     HORN TRIGGER|PURPLE / brown        |- |BECM under pass seat        |
|           WIPERS|RED / grn & blu/grn   |+ |wiper motor                 |
| LF WINDOW UP/DN|gry/wht - gry/grn   |   |in driver door @ door module|
| RF WINDOW UP/DN|gry/wht - gry/grn   |   |in driver door @ door module|
| LR WINDOW UP/DN|gray - gry/org      |   |LR door harness             |
| RR WINDOW UP/DN|gray - gry/org      |   |RR door harness             |
| SUN RF OPN/CLOSE|yel/pnk - yel/org   |   |sun roof motor              |
|   SUN ROOF LIMIT|                    |   |                            |
|        RADIO 12V|purple              |+ |radio                      |
|     RADIO GROUND|black               |- |radio                      |
|     RADIO SWITCH|                    |   |                            |
| RADIO ILLUMINATE|RED / white           |+ |radio                      |
|    POWER ANTENNA|                    |   |                            |
|       LF SPEAKER|                    |   |                            |
|       RF SPEAKER|                    |   |                            |
|       LR SPEAKER|                    |   |                            |
|       RR SPEAKER|                    |   |                            |
Notes:
NOTE: This vehicle has an immobilizer system that needs to be bypassed when adding remote start. Use DEI module 555U. *1 This wire is high current negative. MUST use relay. The fuel door release is lt. GREEN/ gray, low current negative, at the switch or BECM (Body Electrical Control Module) under the passenger seat. *2 Pulsing this wire the same time as lock will arm the factory alarm. Pulsing it the same time as unlock will disarm the factory alarm. *3 To interface with the negative ignition wire to remote start, see directfax document #1500 for wiring information.
Posted By: Velocity Motors
Date Posted: September 18, 2003 at 7:45 PM
You can use a universal bypass module for this vehicle. You will loose a key though.
